Atsarginis uzvedimo raktas :)
Pradėjo Kalapiziukaz, Kovas 04, 2011, 16:46:11 PM
Kalapiziukaz
pasidalinsiu info apie atsarginio avensio uzvedimo raktelio padarymo subtilybes. Kadangi, kai pirkau savaji avensi buvo tik vienas raktelis, tad norejau pasigaminti atsargini. Atstovybe paprase 471,80 Lt su PVM, todel sumasciau geriau pasigooglinti ir pasigaminti pats.
Zodziu parsisiunciau is ebay naudota rakta (110lt manau galima rasti ir pigiau bet kiek ieskojau visi srotai pardavineja su imobilaizerio deze ir nori daugiau pinigu). Taip pat is ebay parsisiunciau nauja tuscia neispjauta rakta ~50lt (jei kas ieskosit tai atsargiai, nes ju yra daug skirtingu rusiu) Ispjovimas kainavo 10lt. Zodziu sumoj raktas gavosi 170lt. Toliau reikejo rakta uzsiprogramuot cia galite pasiskaityt kaip tai daroma: http://www.toyotaownersclub.com/forums/index.php?showtopic=62528&hl=key+programming
O trumpai tai programavimo principas toks:
Reikia istrinti is atminties senus raktus (kazkodel man neistrynus senu naujo nepririso):
You can erase all the keys and start over by turning a working master key 6 times and then opening and closing the door 7 times. Then remove the key and reprogram again.
Naujo rakto imobilaizerio pririsimas:
STEPS:
1. Begin by sitting in the driver seat with all the doors shut.
2. Insert your working master (black) key in the ignition.
3. Very Quickly, turn the key from "LOCK" to "ON" 5 times. (You will end with the key in the "LOCK" position)
4. Immediately, open and close the driver door 6 times very quickly. (End with the door closed)
5. Immediately, remove your working Master key and insert your new Master Key
6. Turn the key to the "ON" position and leave it there while you wait for 1 minute.
7. After the minute, if you want to program another key, just remove the first one and insert the next one, turning it to "ON" and leaving it in position for 1 minute.
8. When you are through programming keys, just take the last one out, open and then close the driver door to lock in the programming, and your done
Mygtuku funkcionalumo aktyvavimas:
1) Make sure that the key is not in the ignition, the doors are unlocked, and the driver's door is open.
2) Very quickly, without turning, insert and remove key from the ignition twice. (leave key out)
3) Close and open the driver door twice. (leave door in open position)
4) Again, insert key into the ignition and remove it. This time only once. (leave key out)
5) Close and open the driver door twice, then close the door.
6) Insert key into the ignition and leave it in the LOCK position.
A. Add mode:
A1) Turn the key to "ON" for 1 second, then turn back to "LOCK".
A2) Remove the key.
A3) You'll hear the doors "LOCK" and 1 second later "UNLOCK" (just listen)
A4) On your remote, press the lock and unlock buttons simultaneously for 1 to 1½ seconds, then let go.
A5) On your remote, IMMEDIATELY press unlock by itself.
A6) You'll get one of three responses:
R1) You'll hear the doors "LOCK", then "UNLOCK" once. The remote is accepted. If you want to program another remote, immediately proceed to step A4 with your second remote, otherwise open the driver's door and the remote is registered.
R2) You'll hear the doors "LOCK", then "UNLOCK" twice. Either you didn't use the same remote in steps A4 and A5(not likely), or this remote was already registered.
The timing was off when you pressed the LOCK and UNLOCK buttons simultaneously and then UNLOCK by itself. Immediately press the two buttons together and the unlock by itself again. Keep trying until you get the locks to signal once that you have been successful. Then if you have another remote to program, quickly press its' buttons as before, until you hear the locks signal once. When you are finished, open and close the driver door to lock in the programming.
R3) If no response, go back to step 1 near the beginning of these instructions.
Viska atlikus teisingai raktas vekia :)
Kaip is fantastikos srities :]] Nu neblogai neblogai ;]
Reiktu ir man raktelio :P
Arturo
aham cia geras :)) tik reik viska idemiai isiskaityt ir suprast kad atlikt viska :)) tai pradzioje istryni visus raktus tada rysi? ten kaip supratau praso senojo rakto panaudojimo... jai ji istrinsim tai kaip ji pagaus?
Kalapiziukaz
pagrindinis neissitrina, istrina tik kitus. Siaip galima bandyt netrinant suprogramuot, bet man neprisiriso neistrynus senu.
MaXas
S_Kulikauskas
Pultelio pririsimas ir Auris toks pats, o vat imobilaizeris pririsau kinietisku laidu uz 50lt, nes neradau niekur, kad Auris galima butu priristi kitokiu budu.
Beje raktelio konkreiciai kokio reikia irgi neradau, tai nupirkau nauja kinietiska bet ne Aurisui, tai netiko "imobilaizerio cipas" todel cipuka teko atskirai pirkti.
Zodziu bendra kaina gavosi 180lt. iskaitant programavimo laida.
Dabar naudoji tik savadarbi, o pagrindinis guli rezerve.
Gaila tik neuzsirasiau koks cipuko skaicius turi buti, tai jai vel kada reiks daryti vel reikes ilgai ir nuobodziai googlinti.
Susierzinau (sory) nu bet išverst galėjai, ne visi gi moka anglų. Būtum padaręs aprašymą, vertą dėmesio pilnai lietuvišką. Dabar gi turiu lišną toyotos rakto "viduriuką" kaip ir susiinteresavau, o čia še tau kad nori viskas buržujų kalba.
naujas32
Nekuriant naujos temos kokio tipo baterija (ismatavimai / numeracija???) eina pas avensi II 2005m d4d?
Raiforas
Issiairdai rakta ir randi visus domenis ant baterijos.
kalava
Citata iš: ketvirtasis Įrašytas Sausis 11, 2014, 17:43:50 PM
A ko cia nervuotis - anglu kalba vis dar nudienos tarptautine kalba.
Gali online vertejais pasinaudot, kad ir google translate - i lietuviu vercia blogai, taciau i vokieciu vercia tikrai neblogai, gal ir i rusu pakenciamai isverstu.
Reikia pamegint.
Jei kas is forumieciu isverstu i lietuviu kalba - info taptu prieinamesne dar platesniam forumieciu ratui
Laisvas vertimas iš pirmo temos posto į lietuvių kalbą.
Žingsniai:
1. Pradėti pririšimą sėdint vairuotojo vietoje su uždarytomis visomis durimis.
2. Įkišti pagrindinį (juodą) raktą (master key) į užvedimo spynelę.
3. Labai greitai pasukti raktą iš LOCK pozicijos į ON penkis kartus. Užbaigti raktą gražinant į LOCK poziciją.
4. Iš karto atidaryti ir uždaryti vairuotojo duris 6 kartus labai greitai. Užbaigti su uždarytomis vairuotojo durimis. I
5. Iš karto uždarius duris ištraukti pagrindinį raktą (master key) ir įkišti naują programuojamą raktą.
6. Įkišus naują raktą, pasukti spynelę į ON poziciją ir palaukti apie 1 minutę.
7. Po minutės, jeigu norima programuoti dar papildomą raktą (raktus), ištraukti pastarąjį ir į degimo spynelę kišti kita bei vėl pasukti į ON poziciją. Laukti apie 1 minute.
8. Kai pririšami visi reikalingi raktai, ištraukiamas paskutinis iš spynelės ir atidaromos bei iškart uždaromos vairuotojo durys. Baigta.
1) Įsitikinkite, kad raktas nėra įkištas į degimo spynelę, visos durys atrakintos, o vairuotojo durys atidarytos.
2) Labai greitai, be pasukimo, įkišti ir ištraukti raktą į degimo spynelę du kartus. Baigti su ištrauktu raktu.
3) Uždaryti ir atidaryti vairuotojo dureles du kartus. Baigti su atidarytomis vairuotojo durimis. (kitos durys uždarytos)
4) Dar kartą ikišti raktą į degimo spynelę ir ištraukti, tik šįkart vieną karta. Baigti su ištrauktu raktu.
5) Uždaryti ir atidaryti vairuotojo duris du kartus, tada uždaryti duris.
6) Įkišti raktą į degimo spynelę ir palikti LOCK pozicijoje.
A. Add mode:
A1) Pasukti raktą į ON poziciją vienai sekundei ir grąžinti atgal į LOCK poziciją.
A2) Ištraukti raktą.
A3) Turėtum išgirsti kaip durys užsirakina ir po vienos sekundės pačios atsirakina. (klausykitės užraktų garso)
A4) Paspausti užrakinimo ir atrakinimo mygtukus abu vienu metu ir laikyti apie 1-1,5 sekundės.
A5) Paleidus po 1-1,5 sekundės mygtukus IŠKART spausti atrakinimo mygtuką dar karta. (bet tik jį vieną)
A6) Turėtum gauti vieną iš trijų atsakymų:
R1) Išgirsite duris užsirakinant ir atsirakinant vieną karta. Nuotolinis užraktas priimtas. Jeigu norite priprogramuoti dar viena nuotolinį rakinimą, pereikite prie A4 žingsnio su antruoju raktu. Jeigu nenorite, atidarykite vairuotojo duris ir registracija bus baigta.
R2) Išgirsite duris užsirakinant ir atsirakinant du kartus. Tikėtina, kad naudojate ne tą patį nuotolinį A4 ir A5 (mažai tikėtina) žingsniuose arba šis nuotolinis jau yra registruotas.
Taip pat ne vienu metu buvo paspausti mygtukai "atrakinti" ir "užrakinti" arba laikyti netinkamą laiko tarpą bei nebuvo paspaustas tik "atrakinti" mygtukas vienas. Bandykite, kol gausite tik vieną durų užsirakinimą ir atsirakinimą kaip R1 žingsnyje. Tai signalas, jog pavyko. Kai pavyks, atidarykite vairuotojo dureles taip baigdami procedūrą.
R3) Jokio signalo iš automatinio durų užsirakinimo ir atsirakinimo. Grįžkite į pirmą žingsnį.
kalava
Didelis dekui kolegai MindaugasB uz rupesti kitais ir vertima!
(y)
judasami
sveiki gyvi,
iškilo problema pamečiau pagrindinį užvedimo pulteltį, liko tik atsarginis raktas, gal žinote, kas Vilniuje galėtų pririšti naują pultelį ir pagaminti užvedimo raktą?
Dėkoju
tojo
Citata iš: MindaugasB Įrašytas Vasaris 02, 2014, 19:16:58 PM
Žingsniai:
A. Add mode:
prasvieskite prasau,
mygtuku funkcionavimo zingsnai, juos praeini, o kas per add mode tada?
