Kaip padaryti kad nepyptu duris atidarius veikiant magui
Pradėjo autoritetas, Kovas 28, 2011, 13:09:57 PM
autoritetas
neseniai radau labai malonu dalyka, kaip pasidaryti kad nepyptu neuzsisegus dirzu, o kaip padaryti kad nepyptu duris atidarius veikiant magui?
darcaa
kelintu metu tavo auto ir ar veikia tas dalykas - nepypimas neuzsisegus dirzu?
Avensis II 2003
autoritetas
Open the driver's side door. Standing outside the car , reach in and
turn the ignition switch to the "on" position. (Do not start the car
and do not lean on the driver's seat.)
2
Press the "ondo / Trip" button on the dashboard odometer Until the
display reads "ondo."
3
Turn the ignition switch off, Then turn it back to the "on" position.
Within six seconds, press the "ondo / Trip" button again and hold it
down for at least 10 seconds.
4
Continue to depress the "ondo / Trip" button. At The Same Time,
fasteners the driver's side seat belt and check the odometer display:
It Should now read, "B-On."
5
Release the "ondo / Trip" button and press it again. The Display
Should now read, "B-off."
6
Turn the ignition switch off. Unbuckle the driver's side seat belt.
Sit in the driver's seat. Turn the ignition switch on again as you
depress the brake pedal. If all Steps have been followed Applet, the
seat belt alert system without Should disabled and no seat belt Alarms
Should sound.
autoritetas
primenu kad dirza reikia segtis visada, 2003m puikiai veikia
Kalapiziukaz
Cia kalba eina apie neuzsegtu dirzu pipsejima, o zmogus klasia kaip padaryt, kad nebutu garso atidarius dureles su raktu spynelej.
Citataautoritetas parašė:
2
3
4
5
6
Should sound.
Kendis
o kaip atgal ijungti reikia viska ta pati daryt ? ar issijungia abejom kedem iskart ar atskirai kiekvienai ?
Kalapiziukaz
Abiem iskart, ir nebutina kaip cia raso ta daryt natsisedus ant sedynes. Man atsijunge sedint be jokiu problemu, ir su uzdarytom durim.
Flemas
Nusilupt plastmase ir atjungti duru davikli, tada nepypses. Tik minusas, kad nematysi ar durys uzdarytos ar atidarytos
Kendis
pas mane dingo keleivio puseje signalas tai turbut kazkoks saugiklis nudege ar kas ? gal kam buvo tokia problema ar susidure ? ka reiktu tikrinti?
autoritetas
as bandziau ir sededamas bet nieko neisejo, beje mano nepersijunge i ondo, bet viskas puikiai veikia, atjungus akuma arba perdegus saugikliui viska reikia kartoti, tinka ir kai kuriem kitiem panasiu metu modeliam
jei nori paklausyt mages atsidares vairuotojo dureles - yra paprasciausias variantas. Atsidarai iki galo langa ir uzdarai duris :) Visos problemos :)
zally
Corolai daroma paprastai-yra nuimama vairo apatine plastmase ir atjungiama dvieju laidu jungtis.Ir nebeuzknisa tas pypsejimas.manau avensyje taip pat padaryta
gisas
paprasčiausia nuo mago atjungti/nukirpti viena laida ir viskas, atidarius duris nepypsės, tik nepamenu kurį. Nuvažiuok pas kokį automagnetolų meistrą ir nukirps jis tą laidą už kokius 5lt :D
Avensis '04 2.0D-4D
kubilas
pakrapštyk ausis močiutes virbalu - tuo kur pančiakas mezga- turėt pypsėjimas nutilt :D ,gal teises nusipirkes- pirmas veiksmas isedus i auto- prisegt saugos dirza.
Kalapiziukaz
Citatazally parašė:
manau, kad situo atveju nepipses kai lempas busi palikes. As savo akuma taip iskroviau galvojau kad pypsi nes spynelej raktas tai o pasirodo lempos paliktos buvo. Zodziu visiskai uzglusint pipsejima ne iseitis. Reik info kaip uzglusint atidarytu dureliu pipsejima civilizuotais metodais kaip pvz dirzu pipsejima.
