salono keitimas
Pradėjo bimas, Vasaris 06, 2013, 21:45:30 PM
1.kazin kiek procentu vairuotoju perskaito instrukcija pries sesdami uz vairo?
2. tiesioginio smugio metu visi asmenys esantys automobilyje visi kaip vienas juda link SRS pagalviu.
Taip, kad bet kuriuo atveju saugaus atstumo niekas nesilaiko.....
Radau keletą sakinių apie airbagus:
Improvements in sensing and gas generator technology have allowed the development of third generation airbag systems that can adjust their deployment parameters to size, weight, position and restraint status of the occupant.
And there's also third-generation airbags, known as "smart" airbags, which compute numerous factors such as weight, height, belt use and so on to determine the type of deployment.
Ieškojau toliau:
Furthermore, the XK's (čia apie 2001m. jagurą berods rašo) driver's seat has a sensor in the seat track to measure the driver's distance from the steering wheel.
Automakers also are experimenting with reflective capacitive sensors, which could determine the mass of an object in a seat and differentiate between a human and a sack of groceries
Ir jau gan tiksliai rašo apie sėdynės poziciją/atstumą:
Advanced airbags were created primarily to reduce the risk of airbag-related injury or death to children and small adults by either deploying with less force or not at all, depending on the situation. Sensors, usually located in the seat and seatbelts, sent signals to the vehicle's computer providing information such as the weight and seating position of the occupant and if he or she was wearing a seatbelt. In the event of a collision, the computer then made a split-second decision on whether to deploy the airbag at full force, reduced force or not at all.
With all the changes in airbag technology, <...> each system must include sensors to detect the size of the occupant, the seat position, seatbelt use and the severity of the crash.
Galantai, nežinau ar čia apie tą patį sensorių kalbame ar ne. Kažkaip šovė į galvą, nes skaičiau ar sakė, užsiminė kažkas apie tas saugos sistemas ir atstumo matuoklius, galvojau, gal čia bus susiję apie sėdynės metaliuką kur minėjo. Paėmiau ir parašiau, poto pradėjau ieškoti tiesa ar melas. Visgi tiesos yra. Bet neįtemą nukrypau, tad admino prašau nepykti, gal pravers kam ši info. Jeigu reikia, gali perkelti į kitą temą :)
Kol rašiau, progys pridėjo postą. Nesu tikras ar ten tas metaliukas susijęs su airbagu ar ne, net nenumanau kaip jis atrodo ir kurioje vietoje. Čia daugiau radau ir pakopinau apie pačius airbagus ir daviklių įtakų jų išsiskleidimo laipsniui/dydžiui/prisipūtimui.
Kaip ir sakiau, tai buvo hipotetinis pasvarstymas (gal ir ne visai į temą) :) :) :)
P. S. Jeigu kam bėdų su anglų kalba, tai arba paversti plius minus galima čia vietoje arba google vertėjas pagelbės (pvz: Anglų - rusų). Kopijavau tiesiai iš šaltinio, neversdamas.
CitataGALLANT parašė:
labai abejojiu ar galima reguliuot pagalves priputima, jug uztaisas yra fiksuotas, o ji padega piro sovinys. Siaip kitose buna du soviniai, bet tai manau del suveikimo greicio o ne del priputimo kiekio.
Gallant visiskai teisus. tas metaliukas matuoja atstuma iki pagalves ir reguliuoja kada issauti pagalvei kad nebutu taip kad is pradziu trenkiesi i vaira o poto sauna pagalve.
Citatamodka parašė:
Tai manau vienintelis logiškas to "atstumo daviklio" paaiškinimas.
Galiu tik pasakyt del amerikietisku Toyotu.Ten atstumo matuoklio nera,bet oro pagalves su dviem kontaktais ir pagalves issovimo greiti ir jega matuoja SRS kompiuteris nuo smugio jegos i kliuti.Pagal tai uzdega viena arba abu uztaisu.Keleivio sedyne turi svarstykles ir keleivio oro pagalve aplamai atjungia jeigu ant jos sedi mazas vaikas.
 Europietiskose Toyotose sistema visai kitokia.Ten vairuotojo oro pagalve su vienu soviniu ir atrodo keleivio svarstykliu nera.Todel labai idomu paliko ka tas atstumo daviklis veikia?Reiks pasidomet :)
CitataVenza parašė:
Europine vairuotojo pagalve eina irgi su 2 soviniais, nes vykdomas 2 pakopu priputimas. Per kazkokia laida sake, kad USA rinkos pagalves didesnes buna, nes zmones stambesni.
 Kai Prius pagalve keiciau,tai buvo su dvieju pakopu USA tipo ir vienos europietiska.
Tiesiog gal nuo modelio priklauso.
d-s
kokie niuansai keiciant europietiska veliura i europietiska odini salona, jei nera sildymo? Bus kur sedynes elektrini reguliavimo pajungti?
Citata iš: d-s Įrašytas Balandis 08, 2014, 14:15:25 PM
greiciausiai,kad nebus. nera sunku 2 laidus datempti.
Toshis
Tai dar reguliatoriu sedyniu, apsildymo pasiimk kur salona pasiiminesi
Sildymui pasijungti dar reikes toyotines reliukes, kuri isistato i saugikliu bloka virs vairuotojo koju ir pacio saugiklio 20A, dedasi ten pat.
d-s
ok, dekui uz info siaip sildymas nereikalingas :), bet vat sedynes reguliavimas tai reikalingas, aisku galiu islupti ir is centrines konsoles sildymo ratukus...
Naujokas
as pasijungiau sedyniu elektra nuo galinio 12v isejimo ("antros priurkes")
Odinis salonas be sildymo?  :think:  Ka ziema darysi? Kepure po uzpakaliu desi?
