Valytas EGR, turbina nedapucia, neranda gedimo
Pradėjo Tuziukas, Kovas 28, 2011, 15:51:37 PM
Tuziukas
http://www.toyotaownersclub.com/forums/index.php?showtopic=114711
The 1st pic shows the EGR valve location when viewed from the passenger side, with the engine cover and airbox removed.
This 2nd pic is with the plastic engine cover removed and airbox hose, cover and filter removed. By taking the airbox out access was possible.
After taking the air filter cover and air filter out, 3 bolts are exposed (12mm Heads) undo these and remove the airbox.
To remove the EGR itself, there are two 12mm nuts and one 12mm bolt holding it on. There are also 2 coolant pipes which I removed (held on by hose clips) which just seem to be for cooling the EGR valve, as one is an input to the housing and the other is the output. Some water came out, so try and keep the hose as high as you can or bung the hose.
The 2 retaining nuts are either side of the EGR valve and the bolt is at the bottom and you'll have to feel for it, as it's not visible from above.
There is also an electrical connector, which operates the valve.
I've pictured the EGR valve removed and the hole it left, for clarity.
To be honest, although it was fairly dirty inside, it wasn't as bad as I thought it would be but (seeing as the car now has 136000 miles on it) I cleaned the EGR using brake cleaner and a toothbrush and manually exercised the valve.
I put it all back together and whilst I was at it decided to clean the MAF sensor with alchohol cleaner spray.
Negotiator
nenoriu pinigų mėtyti bet niekaip neranda problemos. Buvo daryta diagnostika, rode EGR klaidą. Užsiteršęs buvo labai, išvalė. Po poros dienų vėl užsidegė check, rodo tą pačią klaidą. Tik esme kad kartais užgesdavo kartais uždidegdavo. Po to jau pastoviai degdavo padarius vėl diagnostiką rodė tą pačia klaidą, dar priedo pasakė kad turbina nedapučia. Pradžioj vėl išvalė EGR sistemą, tik atrodo nepriėjo iki kolektoriaus (gali būti kad jis nevalytas). Nuvariau tvarkyti turbinos, pasakė kad nedapucia rodo tik 0,7 vietoj 1,0 ar 1,1. Tie kur apžiūrėjo turbiną sakė kad reikia keisti solenoidą. Jų kaina kaip žinia nuo 400-1000 lt. Kokios dar priežastys gali būti?? nes vieni padaro diagnostiką bet netvarko. Būtų gerai kur nors nuvaryti, darytų diagnostiką ir bandytų kažką daryti, ir išspęstų iki galo problemą. Laukiu jūsų  pasamprotavimų.
Negotiator
Is esmės mane ne tiek nervuoja kad nedapucia turbina, bet tas check zekliukas, kai automatiskai ir antipraslydimo kontrole išsijunge. Gal kas gali pasakyt ar turbino valdymo solenoidas gali buti susijęs su EGR vožtuvu, arba gal tai įtakoją neišvalytas įsiurbimo kolektorius? Gal katalizatorius užsikišęs ir tai kažkaip įtakoja EGR vožtuvo (nepraeinamumą) klaidą?
Klausimas,ar gerai isvale egr.Jei jis nesandariai priglunda,gali isleist visa turbinos sudaryta slegi i ismetima.Turetu dumint juodais dumais
Tiutis
Egr issivalysi geriausiai tik pats sakau is patirties... nes meistriukui patikejes si darba jis tau pavirsutiniskai isvalys ir tiek ko pasekoje jokio efekto...
naujas32
Sunku patiket, kad tas egr tokia itaka turi ir taip jis labai uzsikisa, gal reiktu ieskoti bedu del ko ji kisasi? Daugumai auto ji visai uzglusina. Sako, kad net geriau taip...
Tiutis
Taip glusinimas labai gerai nesikisa isiurbimo kolektorius... trauka geresne... gauna sviezia ora...
Tiutis
Deja avensiui nesiglusina meta klaidas.Ir neisprogrmuojamas nes nieko to nemoka bent jau LT
Negotiator
#8
Jo, cia pirmas darbas butu uzglushinti, bet ta pati pasake, kad  bent jau sita variklio modifikacija nesiprogramuoja. Tipo 85 kw yra  triju modifikaciju. Man tas neaiskus dalykas budavo kad tai uzgesdavo tai vel uzsidegtavo check'as. Galvoju gal pats EGR voztuvas striginedavo, kai atstrigdavo tada uzgesdavo checka, o dabar visai uzsilenke..
Tiutis
Issiimk voztuva ir pats pamatysi kame bedos... Mechanine dali bent jau patikrinsi... ipilsi vandenio ir paziuresi ar praeina burbuliukui per sklende ar ne...
Tiutis
Dar tavo vietoj pasitikrinciau oro srauto davikli... Istarauke oro srauto daviklio fyske ir vaziuoji, jeigu vaziuoja taip pat ar ba bisky geriau reiskiasi tavo matuokliui ragas...
